1st in water: Motor ran 4min at 3/4 throttle fine- then started skipping and sputtering and bogged down gurgling etc. - had to tow back-
-replaced fuel filter (it had all kind of debris and some water in it - drained some of fuel off bottom- replaced fuel line bulb
2nd in water: Motor ran 4min at 3/4 throttle fine- then started skipping and sputtering and bogged down gurgling etc. - was able to make it back to dock under 2000rpm still some sputtering and gurgling-
-filtered all fuel in tank 2x with Mr. Funnel- fuel was crystal clear after- replaced the fuel line bulb and filter again-
3rd in water: wouldn't get past 2000rpm w/o major gurgling and sputtering, would idle but would cut off it you didn't maneuver the throttle to keep it alive-
Any ideas thoughts? I want to change the filter that is "on" the engine but don't have any instructions or manual (don't have owners manual) any advice or direction on that would be appreciated- I think that is the most likely next option- I have a ticket working for a service tech but its 6weeks away so i have some time to tinker-
my sister put the boat up, not knowing about ethanol, FULL of ethanol fuel (sat for 6-7months)- please don't start the lectures regarding that- I know- she didn't- but just for diagnostic purposes do I mention it-
Thanks in advance for any suggestions/direction-
