2003 9.9EL 4 stroke won't start
timfives
All-
Hope this summer is treating everyone well. I finally got my kicker on, and of course it won't run.. This is my first attempt to getting it to run, so here is what i've done.
Spark - Yep
Fuel - Nope
I get fuel to the Carb, ( checked the lines at the fuel filter and they had fuel) but not feeding the engine.
( i did get it to fire by spraying in a little starting fluid)
My thought at the moment is that since it has sat for awhile that the carb is gummed up.
Suggestions??
Thanks
Tim
JB
Re: 2003 9.9EL 4 stroke won't start
I think you are on the right track, Tim.
Could be fuel supply, lines, pump or carb.
Good luck. :)
timfives
simple fix,
the jets in the Carb were gummed shut, so after a little cleaning and TLC she fired right up!.
Thanks
t
