Re: 2003 350 EFI mag Frustrated and need help
Your 1983 intake will NOT fit the Vortec heads. And as mentioned above, your 2003 block may not even have a place for the mechanical fuel pump. If it does, then an intake manifold is your only other purchase.
You don't need a different wiring harness, as Merc engines are plug and play. The 2003 engine is plugged into your 1983 harness right now.
