2002 yamaha 40 cherping every rotation under load
kevin11mic
I have a 40 horse yamaha that will make a cherping noise every rotation when it has a load. Any ideas what the noise could be
99yam40
Re: 2002 yamaha 40 cherping every rotation under load
Running Too lean?
Most of the time you hear about a lean sneeze due to carbs plugging
Capt Ken
I was think some birds built a nest under the cowling.
kevin11mic
Not too lean...the motor runs great...it makes the noise when I put it in geer under a load...saw something somewhere else about a shaft seal?
Capt Ken
You are speaking of the shaft bushing but yours doesn't have one.
kevin11mic
Well any ideas?
robert graham
Motor might "run great" but still have a lean fuel condition in a carb...drain each carb onto clean white rag to try and check for water or debris in float chamber. Lean condition can kill that cylinder...Maybe run the motor with upper cowling off to see if "chirp' is mechanical rather than lean carb mixture?
99yam40
how can you tell it is chirping every rotation of motor ?
at 1000 RPM that is a lot of chirping and I do not think you could tell it was even a chirp, more like a squealing noise.
Cylinders need more fuel under load, so I would be looking at carbs to start out with
Capt Ken
You sure it's not trying to alarm? I had the identical engine in my shop today and noticed the alarm led's on the lower front cowling. Make sure you arent getting a red light. Is this a tiller model?
kevin11mic
It's a remote steer...the sound is like a metallic sound...gonna check the carbs tomorrow
