2002 Volvo Penta 5.7gi-b engine overheating
TJoyner
Engine overheats with alarm and stalls engine after plane. Dashboard temperature gauge shows normal, but engine is hot around oil filter. Is it thermostat?
Welcome aboard. Is this a new to you boat, or have you had it for a while? What maintenance did you do?
TJoyner
I’ve had it from day one. I’ve changed oil, gear oil, oil filter, fuel filter and steering actuator in the past few weeks. Just getting it ready for the summer. It’s been garage stored all along. Since Covid, we’ve only had it out 1-2 times.
when was the raw water pump impeller changed?
did you pull the drive and inspect the bellows, u-joints, and Gimbal?
TJoyner
Impeller was changed last year and I pulled it this year and it looks perfect but I do have a drip and have tried a few times to reseat it. No I have not pulled the drive to inspect bellows, ujoints and Gimbal.
alldodge
With boat in the water remove the hose going to the thermostat housing from the water pump. Start the motor and see if it come gushing or barely pouring out
Dont forget to inspect the fitting on the drive that the raw water supply hose connects to. That fiting often corrodes.
Overheat is a lack of cooling water flow
The leak from your raw water pump could also be an air leak causing the pump to loose prime.
When you changed the impeller last year, did you find all the missing pieces?
TJoyner
I'll check the raw water supply hose today. The impeller was good when I changed it, no pieces missing...just wanted to make sure it was good.
TJoyner
Could I do this with a muffler hose? I won't have it in the water today.
dubs283
Looks perfect and performs properly are two different things. Even though the impeller looks okay it does not mean it works okay. Often times the impeller has a set that causes it to not pump enough water to cool properly, this is especially true of aftermarket impellers.
Is the drip from the housing cover or the shaft? Could be the shaft seal has failed and pump is drawing air
Try the test suggested above and check for proper flow at t stat housing. Test can be performed on muffs with full water supply from hose. I would also check supply to the pump from the drive by backflushing the supply hose
alldodge
Another way and less mess but still needs to be in the water. Get a short piece of clear hose and a double barbed fitting from hardware store. Should be about 1 inch ID. Place it between T stat and hose from pump.
Your looking for bubbles when running
