2002 merc starting procedure
dhughes49
I just bought this motor and having a little trouble starting when cold .Could someone give me the official starting procedure for this motor . I hear there is one but I cant find it . Its a 2002 merc 150 saltwater. I had a 96 Johnson before and had no problem just choke it and it started . This is a different critter. After I get it started it just takes a touch of the key and it fires right up and runs great .
carholme
Re: 2002 merc starting procedure
Here is the owners manual for your engine, manual 10126Z20:
10126z20 - Download - 4shared
Click on the Download button under "View Document" and when the next page opens, select Free Download.
Gerry
dhughes49
alright ! thank you very much!!!
dhughes49
I don't know what kind of virus program u hooked me up with but thanks a lot it's trying to take my computer over . what made u want to do that ?
dhughes49
Could any one else give me a hand with out giving me a predator program .like carholme did.
MH Hawker
One thing I am sure of is that carholme would never do Is hand out any sort of virus
carholme
MH, thank you, much appreciated!
Hughes;
This is the first time I have heard of a problem and am sorry you experienced it but I use 4 shared all the time and have just downloaded the same file that you did without any hint of a problem.
Gerry
dhughes49
Adware would have been more correct than virus . I didn't like it changing my computer setting. Im sure you were unaware. No hard feelings .
Silvertip
Honorary Supreme Mariner
1) Squeeze primer bulb until firm
2) Raise fast idle lever about 1/3 up
3) Turn key to RUN (not START)
4) Push in on key and hold for a count of 8 - 10 (this is what primes the engine and functions much like a choke woujld)
5) Turn key to START
6) When engine fires lower fast idle lever to a slightly fast idle. Be ready to bump the key (push in momentarily) if the engine begins to die. Don't wait until it dies to do this. Your ears tell you if the engine is beginning to quit.
7) When warm, fully lower fast idle lever and go boating.
There is an option for #4. That is to hold the key in WHILE you crank the engine. Somewhat faster starting may occur using the procedure as stated.
