Tubingluvr
Thread starter- Joined
- Feb 23, 2007
- 426
I have a 2002 Pontiac Firebird with a bad engine miss.
Misfiring on Cylinder 3....I have put in new plugs and wires and checked the primary and secondary resistance on coil pack and did a compression check and everything checks out fine.
Misfire on cylinder 3 is the only code it is throwing.
I have a snap-on Fast trak graphing scanner so i can see what all the sensors are doing and everything looks fine.
I am thinking intake gasket..........what do you think?
Oh I am sorry, forgot to tell you......it has a 3800 (series 2) with 133,000 on it.
Is this engine known for intake gasket problems like the 4.3......I believe the 3.1,3.8 and 4.3 are all the same block, just different bore and stroke...right?
