2001 Yamaha F80 Compression
handi2
Hello,
I want to do a quick compression test on a 2001 F80 outboard. I know a leak down test is required for an acurate test. I am changing the spark plugs and engine anodes so I would like to do a quick compression test.
What needs to be done to do this? I have never done a compression test on a 4 stroke outboard engine. It is a carburated engine with no EMM.
Do I need to ground the plug wire?
luskateer
Re: 2001 Yamaha F80 Compression
also you need to do the test with "Wide Open Throttle". Otherwise the reading is about half what it should be.
Ground the plug wires.
All plugs removed
