statsman77
Thread starter- Joined
- Jun 1, 2012
- 8
Will not start unless I spray starter fluid in. Coke works. Once running it runs great. I checked the compression on all 4 of the cylinders and they are all close together and within specs. I tested the spark with a gap tester and good. Using good fuel and primer bulb checked. Starter engages and spins flywheel. Took off carbs and they looked squeaky clean. My guess might be fuel pump bad, starter not spinning fast enough even though it seems to. Any suggestions, I want to get on the water without using starter spray. Thank you - Paul
Spark test - http://youtu.be/t_qgrwcswTM - DID video because by my self.
