2001 trophy walkaround prop
mikenjo
I have a 2001 trophy walkaround 2002 with a 150 mercury the prop on it is a 15x17 aluminum its gouged a dented so i needto replace it my question is this the right prop for the boat i get around 35mph out of it 5100 rpm
steelespike
Re: 2001 trophy walkaround prop
Your rpm is at the bottom end 5600 being the max 5000 the minimum. but I would check the setup before a prop change.
Is the bottom clean and smooth?Does the throttle open all the way.Is the motor in excellent tune.Are those numbers with a dinged up prop?It may be cost effective to get the prop repaired and get some fresh numbers.
