RollinEEZZ
Thread starter- Joined
- Oct 29, 2016
- 21
Greetings,
2001 Johnson 30 HP Model#: J30EVLSIA
The outboard shifts from neutral to forward OK. Going back into neutral from forward the prop stays engaged into forward gear.
In order to shift back into neutral from forward, the engine operator must move the remote control a little past neutral (almost slightly into reverse).
The outboard engine shifts OK into reverse. The engine also shifts from reverse back into neutral OK.
The only problem is shifting back into neutral from forward.
The shift linkage connection to the gearcase on this model is inside the raw water pickup. (SEE PICTURES). Also posted is a photo of the connection from the shift cable to the outboard.
I do not have a manual and also have no experience w/ outboard shift linkage adjustments. Can someone please provide a detailed step by step process to correctly adjust the shift linkage?
Thank you for sharing your knowledge
