2001 Johnson 115 surging at wot after warm up.
Seale_eric
Motor idles fine and hops up on plane fine. Can idle the lake forever with no problem. Run across the lake and it will randomly start "surging" (just like I'm pumping the throttle). I have experimented a little and and once the surging starts it will idle fine and run great until about 2500 rpms and then start surging again. This will continue until you kill the engine, however as soon as you kill and restart the engine, it will hop right back up on plan and run like brand new. VRO was taken off 6 years ago and they replaced it with an inline electric pump. Around the same time the surging issue started, I also was loosing prime in my fuel line while the engine was off (ran fine but just had to reprime to crank) I replaced the bubble and the electric fuel pump. I don't have the priming issue anymore but it's still surging. It does seem to take longer for the surging to start since I replaced the fuel pump tho. Yesterday I probably ran a mIle or more before it started. I also ran an external fuel tank right at the motor to take the gas tank and fuel line out of the equation and it still did the same thing. Any ideas?
jakedaawg
2500 rpms is when the SLOW system kicks in.
Sounds like it never ran right with the electric pump so maybe replace that with a vacuum pulse pump the way 99% of the rest of us delete the VRO system. There is a link for a how-to in the sticky at the top of forum.
I would guess that you have either a bad pack kicking in the SLOW or an overheat warning. You will need to get the fuel side right to diagnose I would think.
