Seale_eric
Thread starter- Joined
- Jul 9, 2017
- 1
Motor idles fine and hops up on plane fine. Can idle the lake forever with no problem. Run across the lake and it will randomly start "surging" (just like I'm pumping the throttle). I have experimented a little and and once the surging starts it will idle fine and run great until about 2500 rpms and then start surging again. This will continue until you kill the engine, however as soon as you kill and restart the engine, it will hop right back up on plan and run like brand new. VRO was taken off 6 years ago and they replaced it with an inline electric pump. Around the same time the surging issue started, I also was loosing prime in my fuel line while the engine was off (ran fine but just had to reprime to crank) I replaced the bubble and the electric fuel pump. I don't have the priming issue anymore but it's still surging. It does seem to take longer for the surging to start since I replaced the fuel pump tho. Yesterday I probably ran a mIle or more before it started. I also ran an external fuel tank right at the motor to take the gas tank and fuel line out of the equation and it still did the same thing. Any ideas?
