2001 hydra sports power plug-in
srinehults
Hi all. I have a 2001 Hydra-sports 23 foot. I am in the process of putting it in a permanent slip at a marina. I would like to plug into the external power source. But cannot find a plug-in on the boat. Does anybody have an idea where I would find it or do I need to add one? Thank you for all comments.
mr 88
Unless you have a control panel that clearly shows your AC options the odds are you are not hard wired in for AC current . Do you have any 110 outlets or a onboard battery charger ? It's pretty hard to miss the shore power outlet on a boat . Usually they have a big 3- 4" diameter chrome screw on cover plate to keep water out when not in use .
srinehults
Unless you have a control panel that clearly shows your AC options the odds are you are not hard wired in for AC current . Do you have any 110 outlets or an onboard battery charger ? It's pretty hard to miss the shore power outlet on a boat . Usually they have a big 3- 4" diameter chrome screw on cover plate to keep water out when not in use .
I don’t think I do. I believe the boat was forever trailered, so never had the need for external power for keeping batteries charged. I will have to look into adding. Thank you for the response.
