2001 ficht low voltage
Jeanvern
So I have read a few post over here and I think I'm on the right path but I would like to confirm before I buy a new PDP. The issue started when my starter didn't engage the flywheel so we brought the gear up and started the engine. We turned it off and started again and no issue for the next 2 operation. Then the starter failed because the gear wouldn't spin but heard it spin inside so I bought a new one. It lasted about 4-6 times and when I pulled out of the marina, my check engine went off but didn't notice any anormalities and it was pissing water. Pulled to the dock and turned it off, waited 5 minutes and tried again but the starter didn't have enough juice to go more than a quarter turn. Looked at the solenoid and it was really green so I went to the local shop and the mecanic bypassed it with a screw driver and the starter worked so I bought a new one. Still won't crank more than a quarter turn and my fuel pump is not priming.
As per a previous post, I cheched the yellow/blue wire at the solenoid and I have about 4 volts. I also measure the voltage at the fuel pump and have less than 4 volts. I checked the gounds between motor and battery, from the EMM, under the solenoid and it looks good. I also verified the voltage between the red and black at the PCP and I have 12 volts. I then checked the voltage on the red/black fusible link between the PCP and EMM and I got 4 volts.
My questions is: should I get 12 volts out of it and is it feeding the EMM or is it the opposite?
Any help would be greatly appreciated.
boobie
First thing to do is have your battery load tested. Then check All the battery cable connections. Yes there were some bad PDP's out there and some guys took them apart and fixed them.
Jeanvern
I agree, I have two new batteries and they were load tested and I cleaned all connections and ground before looking anywhere else. I looked further at the wiring diagram and found the one for the PDP so my next step is to look at the red cable which is coming from the power relay/ EMM and I will trace it back to the EMM. I'm really hoping it's the main power relay but I don't have too much hope.
RK
I have 2001... just trying to read posts and learn as much as I can about he engine.. so... what's a PDP? thx
Jeanvern
Just to update everyone. I looked at the wiring diagram and checked the voltage to the PDP and didn't get much, about 4V in the fuses connection. I then checked the main power relay and nothing going to the EMM and PDP. I wacked the relay with a wrench and then voltage started building up so I assumed it was a bad relay. I got a new one for $40 and I'll be fishing tomorrow. Lesson learned is don't assume it's the PDP or EMM, check voltage as per the wiring diagram and don't switch the battery switch when an engine is running!
