2001 Cabrio 290 Winlass Solenoid Location
Dlake64
My windlass has stopped working, I have power to both sides of the breaker, and both sides of the switch. I don’t not have power at the windlass. I assume I have a bad solenoid however I cannot find it. Does anyone know where their they located the solenoid.
Nheels
Hey, I have an 08 Larson Cabrio 330 and the windlass is a Maxwell.
My solonoid is mounted on the firewall in the engine compartment. If you have a fuse for it, you can trace the wires from there.
Dlake64
Thank you for your reply unfortunately I have not been able to locate it in the engine compartment. I’ve traced the wires from the windlass back through the cabin and it appears to run along the starboard side but I loose the trace at the helm.
Nheels
Have you googled the windlass make and model for an installation manual? It may give an indication perhaps.
Dlake64
I have the manual it’s a Lewmar sport 550. It’s no help only that there is a solenoid
dingbat
The solenoid is mounted by the person/company that rigged the boat. It could be anywhere. Mine is in the cabin
