2001 60HP Yamaha Impeller Change Question
Brian66
Do I need to put the motor in a specific gear(F,N,R) before I drop the lower unit? Seems like I heard this is important. Please help.
Brian
zzzzz
Re: 2001 60HP Yamaha Impeller Change Question
neutral is fine...Mercs are the ones that matters with :cool:
caseyg3
Re: 2001 40HP Yamaha Impeller Change Question
My heat alarm goes off when engine idles for a while but goes off when i bring the rpm's up. Should I change teh impeller first and that might fix issue? Motor is about 9 years old and I have never changed. Is it very hard to change?
Thanks,
99yam40
Start a new thread with your problems/questions,the one you posted on is a 2008
