2001 225 Johnson losing spark
Brianfish
Hope you can help me find this problem.<br />I thought it was the shift switch, which was bad,<br />but its still losing fire after warming up.<br />Motor runs great for 1/2 mile then spark breaks down. Ran great before I had a water pump put in.<br />Could the mechanic have done something that would have cause this?
v12mac
Re: 2001 225 Johnson losing spark
Do you have a temp gauge? Is the tell tale squirting a good stream of water? Do you get an overheat alarm? I am not a mechanic but it sounds like something may have been missed during the water pump change. <br /><br />Mac
Brianfish
Have gauges,the temp is fine and pressure is too.<br />Its seems to me from what little I know its either the Stator, power pack or wiring harness,<br />just havent checked them out yet.Heard it could even be a bad ground causing voltage lose?<br />Hope someone can point me in the right direction?<br /> Go Fish!!!
Brianfish
wanted to add that we have already ruled out fuel<br />problems, its definetly spark and its there till you run it. Thought for sure it was the shift switch because it was the first thing I checked out and like I say it was bad, but not the only problem.
Solittle
How, exactly, do you know that it is spark?<br /><br />Before you completely rule out an overheat I suggest that you run the motor with the cover off. When it starts to slow down shut it off and feel the heads. Guages have been know not to tell the full story.
Brianfish
thanks for the responses, but its not getting hot<br />the water is cool and the heads are too.<br />gonna break out the tester soon and try to find<br />the problem. Its got fuel,and spark till its ran <br />hard. Just hope to get it this next try!!<br />Need to fish!!! At least it hasnt had to be towed yet!!!
Cricket Too
Have you done any troubleshooting at all yet? What is this "tester" you speak of? Does the engine stall when you lose this spark or are you losing a cylinder or two? These are the basic troubleshooting procedures to start with, you have to start with the basics if you start getting too involved you will start burying yourself and working backwards. Let us know exactly what the engine is doing.
OBJ
Might as well put in my .02 worth. Brian....if ya' don't have a service manual, get one. It will pay for itself in the long haul.
Brianfish
Thanks for the input!!!<br />I have a service manual and my friend has a good multitester. Thats how we found out we where losing the starboard cylinders because of the shift switch. Havent tried anything else yet.<br />Just thought someone might have a suggestion on where to start looking first.
Cricket Too
If you are saying that you are losing the entire starboard bank of cylinders after Quickstart or soon thereafter, you may be looking at a bad power pack. But deffinetely do some troubleshooting to be sure, you should post what you find so guys on the site can help you out and walk you through it, they have helped me figure out problems every time I have asked. Good Luck.
Brianfish
It was losing entire starboard side because the shift switch was bad but now its still losing fire after it warms up. Did check out the heat sensors today and they are fine. Guess Im gonna have to keep checking the cheaper parts first<br />and hope to find it this weekend. Need to fish!!<br />might just be a coil breaking down? Or that 1<br />and only power pack. If it only had 2 like my 115<br />I could just swap them. If I only had a good tester of my own. Anyone have any suggestions on <br />multi-testers and where to buy them?
