2001 225 evinrude fitch stalls when shifting forward or reverse
Wilderg88
Hello everyone. I recently bought a 23ft spacecraft that came with a 225hp 2001 evinrude fitch everything has been good except for one thing. The motor always stalls when shifting either forward or reverse and only in water. Dosent stall when shifting outside of water. Only way to avoid this is to shift fast and give it enough throttle where the motor revs before it dies. After its enguaged and above 1300 rpm it drives perfect no issues even wot 5500 rpm no problems i have tried all the below with no luck.
New oem spark plugs oem
New fuel lines
New fuel filter oem
New water separator
New aftermarket primer bulb. When i first replaced it the first time out of the marina it shifted fine dint stall but otw back started doing it again. So replacing it with oem to see if it fixes it
Fuel tank is plastic and clean
Fuel used is 87 with ethanol doctor stabilizer
Hoping someone has some input on this and hopefully i can get it fixed all info is greatly appreciated! Thanks all
rjcamel2355
Someone may correct me if I am wrong, but those engines have a **** interuptor switch? that cuts 3 cylinders (????) off when shifting from, or into neutral, that may possibly be faulty. It may not work exactly how I am describing, but I know the 99 I worked on awhile back was having a similar issue, and replacing that switch fixed it.
Wilderg88
Anyone know where its located on my motor? Ill try unplugging it see if it stops stalling and if it does ill just replace it
daselbee
Yeah, it is there. You will probably have to remove the stbd lower cowl to get to it. If you can picture the area directly below the point where you attach the shift cable to the engine linkage, then move forward a few inches, it is down low below the lowest intake plenum. It is not as far forward as the air silencer, tho.
You will see a kinda intricate mechanism that moves when you shift, with a push button switch on it. There are two wires to this switch, one black, and one black/yellow. You can try disconnecting it, which was the tried and true way to debug this switch on a carbed motor, but the results may be misleading.
However, any fault in the shift assist circuit will trigger a Check Engine light, and store a code 28. ( Which will happen if you disconnect it.)
When I was having that issue, it turned out that the shift rod was binding in the shift rod cover, forcing the switch to activate for too long. I replaced the shift rod cover and the problem vanished.
No, it was on my '98 Johnny 150HPV6. I would expect his motor to have the same shift mechanism, though, since the year is close.
daselbee
Same shift mech for sure. But your switch feeds the powerpack, and this switch feeds the EMM. It surely would be a difference in how the engine reacts to an extra long switch closure.
For example, the Ficht has an idle speed control routing programmed in the EMM. It tries to keep an even idle speed at all times. When the switch momentarily closes during a shift to neutral, what does the EMM do? Does it kill three like yours, or does it drop idle speed and then pick it back up?
I don't know.
But I will keep this in mind for future issues if they arise.
Wilderg88
I have yet to try the shift switch. Going to try it today to see. And it only does it in the water. I wonder if i out a big bucket of water under the prop if it would do it
Wilderg88
So i replaced the bulb and checked the switch still same problem. And now seems i have a fuel restriction because the bulb was collapsing and motor was shutting off. I also noticed when priming the bulb i was seeing air bubbles in the line filter I have. Assuming thats not good
daselbee
Just checking....don't shoot the messenger.....did you install the bulb in the correct direction? There is an arrow on it.
If the primer bulb collapses, there is a restriction between the bulb and the fuel tank. The antisiphon valve and any fuel filters are prime candidates for causing this.
Wilderg88
So i fixed the fuel issue the idiot who installed it before me routed it under the fuel tank and when the tank was full it was squishing the line. Routed line correctly and fixed that problem. I tried the disconnecting the shifter switch and for a while the problem was gone i thought i had finally figured it out. Then it started doing it again although it was better. I just cleaned the exhaust pressure sensor dint look to bad but cleaned it anyways and did a compression test 120 on all 6 cylinders. Another thing that it started doing is it would stall after crusing above 3k rpm for over 15 to 20 minutes. Motor would just die and not want to start unless we prime it. Also note the primer bulb is installed correctly. Any other suggestions? What i dont understand is why it runs and shifts perfectly outside of water but when its in the water it starts acting up. Maybe its a land motor lol also forgot to mention i changed my plugs and indexed them like 3 trips ago and when i did the compression test they look like this. Is this normal?
daselbee
Well, it sounds like you are obviously running out of gas. Run for 15-20 mins at 3k, and stalls. Then you have to prime the system with the primer bulb....classic out of gas symptoms. Possibly a weak lift pump.
daselbee
5000885.....Boats dot net, duskyonline, offshore marine parts, ebay (used)...etc, etc, etc. 480 bucks
I get my stuff from Duskyonline. 400 bucks roughly. They are in Dania Beach, BRP warehouse is in Ft. Lauderdale....so they are fast!!!
Pricey to just shotgun it without testing what you have. Put a fuel pressure gauge on the fuel rail at the Schrader valve.
You must maintain 25 psi. Test run it and see if FP drops off when it stalls.
Once stalled, pull the return line for fuel BACK to the vapor separator, and see if the vapor separator is out of gas....
Getting that return fuel connector off is a bit tricky. Press in on the red tab you see at the mouth of the connector, hold it in, and pull connector off.
Don't break it...unless you want more expense in a new fuel manifold assy.
Get it running again, and while cruising, have someone give the primer bulb good even squeezes. If the lift pump is truly weak, you will be supplementing it's pumping power with primer bulb assistance. That should keep the fuel supply to the engine constant, and not allow it to run out....
Stuff like that....
