Hello everyone. I recently bought a 23ft spacecraft that came with a 225hp 2001 evinrude fitch everything has been good except for one thing. The motor always stalls when shifting either forward or reverse and only in water. Dosent stall when shifting outside of water. Only way to avoid this is to shift fast and give it enough throttle where the motor revs before it dies. After its enguaged and above 1300 rpm it drives perfect no issues even wot 5500 rpm no problems i have tried all the below with no luck.
New oem spark plugs oem
New fuel lines
New fuel filter oem
New water separator
New aftermarket primer bulb. When i first replaced it the first time out of the marina it shifted fine dint stall but otw back started doing it again. So replacing it with oem to see if it fixes it
Fuel tank is plastic and clean
Fuel used is 87 with ethanol doctor stabilizer
Hoping someone has some input on this and hopefully i can get it fixed all info is greatly appreciated! Thanks all
New fuel lines
New fuel filter oem
New water separator
