Looking for some help. Picked up a new ski a few weeks ago and it was a non runner. Drained the old fuel, new battery and plugs and it ran like a champ. The first day on the lake I start/stopped it a bunch of times.
The next day it started a handful of times then died on me. Dead battery.
I replaced the stator and put everything back together. It ran for about 30 seconds on the hose then I shut it off. I went to start it again and it fired up to. I remembered that I had changed the oil lines (I primed them up to the carbs) so I wanted to be sure it was flowing into the carbs. Tried to start it again and all I get is a clicking from the solenoid. I have power on the hot side, pressed the start button and got power to the other side.
I checked for continuity on the negative side of the starter solenoid in the electrical box and it was ok.
Any idea what I should check next?
Thank you in advance for the help!
