scb1712
Thread starter- Joined
- Jul 25, 2011
- 105
Hi All,
I just purchased my first boat, a 2001 Glastron SX 175 and it appears i've made every mistake possible :facepalm:. The boat was used in salt water for the first 8 years, but has been brought up to Canada and run in fresh water ever since. The previous owner put about 30 hours on in last season, but the boat overheated on his last outing. During the winterizing, he had a new impeller installed and pulled out lots of pieces of the old one at the inlet side of the circulating pump.
On our first outing this year, we ran into problems with the boat overheating badly (225 deg) after only about 5-7 min of running between 2500-3000 rpm. After shutting it down, and letting it cool, we were able to nurse it back to the dock keeping it at idle or just above (where she stayed around 180 deg).
So far, we've pulled and inspected the impeller and it's in seemingly good shape. I might replace it just to be safe. We have flushed all of the lines etc. and seem to get water flowing all the way through. However, the water presssure coming out of the impeller (when running with muffs on) was quite poor as i could stop it by placing my thumb over the hose.
We also noticed that there was no thermostat installed so that has been ordered. In addition, we noticed that 3 of the 4 channels where water flows into the exhaust riser were completely blocked by rust/corrosion. A new riser is also on the way.
I'm just wondering if there is anything else we should be checking to try to get this issue solved.
Sorry for the long post, but any help would be much appreciated.
Thanks,
Scb
Thanks,
Scb
