How to manually raise motor that wont trim up (not trying to remove motor off transom). Exterior trim rocker switch on motor will only work on "down position". Checked the exterior rocker switch in "up" and "down" mode and both trim relays/wiring and all check in good in power up and power down except trim motor only runs in the "trim down" mode. I see the thick blue motor lead wire is up and the thick green wire lead is down to the trim electric motor.
So what I need to do is manually raise the motor up so I can get at the trim motor lead connections. I open the slotted manual screw to open but can not "raise the motor" at all. Also I have a stand off jack mount that bolts to transom that gives me plentt of room to get at trim motor once motor is raised or trim up. Thanks
