2000 Stratos need help identifying
HHosford
Just bought a used Stratos with Ocean Pro Evinrude 150 and 2 axle tilt trailer. Title reads 1996 on the year but there is a tag on the inside of the boat that Definetely reads " 2000 Stratos " but can't make out much more past that id on the tag other than 8 person capacity or 1096 lbs. 1671 lbs Persons Motor Gear and max motor hp of 225.
This boat has a split console and is approximately 20' (title reads 19' 3")
Can anyone tell me what Type or Make of Stratos this is?? Guy I bought it from said they only made a few the split console. Have found no other pics or info that seems to match.
Thanks for your help.
first boat
Re: 2000 Stratos need help identifying
you have a stratos 2000 dc. 2000 is the model number, dc means dual console. I just got a 92 stratos 2000 dc with a johnson 200.:p
cbass74429
Serial # will tell you. Take number to a dealer, or call one give him number.
It will tell you all about boat.
Hope this helps David C Sr.
rickgess
Last two numbers in the serial number are the year
