Lizzy K II
Thread starter- Joined
- Jun 30, 2010
- 12
I'm having an issue with one of my 2000 model 200 hp. Optimax engines. The motor starts fine and runs great below 3000 rpm. However, when you try to run the motor above 3000 rpm sometimes it starts to fluctuate and stall. It never stalls to the point where the motor will die, but the rpms will rapidly fluctuate. I have a DDT scanner and no codes or check engine lights are shown. The only fault codes that are occurring are battery faults. I had the alternator checked and it seems to be working properly. I also made sure I had a good battery, and I even moved the battery right next to the motor and connected it straight to the cables coming out of the motor.
Does anyone have any idea what might be causing this? About a year and a half ago I had all the diaphragms in the air and fuel regulators replaced on the fuel rails as well as the tracker valve.
I'm at a loss as to what might be causing this.
