lanier2008
Thread starter- Joined
- Jun 15, 2008
- 2
I have a year 2000 60HP Johnson motor that occasionally goes into SLOW mode operation and the problem is becoming more frequent. When I start the motor, it goes thru the alarm check cycle and everything seems to check out OK
I have had a few days that the motor ran fine (5200 RPM) all day but typically I get on the lake and everything runs good for about an hour. Then the RPM suddenly drop to 2500 RPM without any warning lights or alarms. I was told that overheating is the primary cause for this and, to this point, I have replaced the thermostat, water pump and temperature sensor and had the carburators cleaned but the motor still goes into slow mode with no waring. When this occurs, I can hold my hand on the engine and it's not hot.
I have had a few occassions whre I stopped the motor for an hour, restarted, and everthing works OK again.
There have been several occasions where the motor will not exceed 2500 RPM from the time I leave the dock until I return.
There has been one occassion that the motor dropped to SLOW mode for about an hour and then kicked back up to full RPM while I was heading to the dock.
My oil reservoir is full and the motor is using oil. The motor seems to run smooth even when running in SLOW RPM mode
I am a new outbord motor user and sure could use some help with this.
Thanks,
Thanks,
