2000 johnson 60hp help
wilson750
Motor cranks slow. Tried 3 fresh batterys. All slow crank. Checked grounds. Will start with pull rope on flywheel. Any help to this would be great. Im on vacation with this problem
Honorary Supreme Mariner
Yes it will.------Turn key to on.-----You have to use the red lever on the primer and squeeze the primer bulb once.----Return red lever to run position.--Pull the motor over.----Motor will start and run with a dead battery.
wilson750
Battery is not dead.I have stared it with rope.thinking starter went bad? Open for suggestions.
