100-31keith
Thread starter- Joined
- Mar 30, 2018
- 2
2000 Johnson 50hp on a 17'2" SeaArk bass boat. Less than 15 hours total use. Ran perfect back in the day and perfect the last time it was used in 2006 (yes, it has been 12 years). Inherited last month from deceased dad.
Last week, I put in 2 gallons of gas (50:1) and a relatively new battery out of one of my vehicles (temporary for the "test", lol). I also filled the oil mixer as instructed for still in break-in. Launched.
Squeezed the bulb, pushed the button in, moved the lever forward. Pumping the key, it started after the third attempt with normal high rpms. As soon as I put it in neutral, it died and did so the next two attempts.
So, with the next attempt....
As soon as I was back in neutral, I immediately put it in gear to keep it from dying. It ran, but at a very, very, very low speed (perhaps 2 or 3 times the speed of trolling with a crank bait). It was very smooth, no smoke, water pump working. I ran it for less than 2 minutes before deciding not to push it any more. The maximum speed did not vary or increase.
Could the cylinders be binding from age and non-use thus limiting the speed? Some type of fuel restriction issue (i.e. filter)? Anything else possible?
Your input will be appreciated.
