2000 Johnson 50hp Idle Adjustment
whozleft
Can anyone tell me where the idle adjustment screw is at on this motor please?
Also, my volt meter tops out completely when the engine is running. The marina checked it before I bought the boat and says the charging system is ok. Does this mean I need a new volt meter or is there something I can check before buying a meter and installing it?
Thanks for the help. This is my first post to the forum.
tashasdaddy
Re: 2000 Johnson 50hp Idle Adjustment
what is your idle problem. take a volt reading on the battery, then start motor and see what it is reading. post readings.
