2000 Johnson 50 hp bogging at 2500rpm's
JPowell01
Hey guys!!!!!!!I'm new to the forum. Found yall a couple of days ago..Got a question.:) I have a 2000 Johnson 50 hp that is going in slow-mode..Redone the carbs, put manuel fuel pump on it, changed plugs,waterpump,and thermostat...What i found out is that the tan wire behind the circuit board type on motor had rub raw and was touching the block..could that be why it was going in slow-mode???Plus, I did the temp-switch test by grounding it to the block, Nothing!!! No light nor buzzer!!!Could I have a bad powerpack?Why i don't get a buzzer when I do that????:confused:
