2000 Johnson 175 oil tank placement ?
JJB
How far from the engine can you mount the oil tank ? I have a cuddy cabin and it would mount nice under the step in the cabin , if thats not to far . Its about a 16 ' run to the engine !
OBJ
Re: 2000 Johnson 175 oil tank placement ?
Actually the oil reservoir is recommended to be mounted well forward of the bilge area to prevent it from getting swamped and getting water in the oil. Can't tell you though right off the top of my head how far is to far.
Dhadley
Good question. I can't remember right off the top of my head but there is a spec based on resistance in a 5/16" hose. However in the accessory catalog the replacement oil hose (listed specifically for oil tanks) comes in 25' rolls so we'd assume that 25' would fall in their spec.
Obviously if you move the tank, mark the tank and verify the useage vs. the gas burned. Add oil to the gas while you're verifying everything.
OBJ
Dale....either I'm blind when looking at the stuff or I'm assuming and not looking.....think I said that right....but I thought oil line was more like 1/4" ID.:/
Walker
The flow is so slow that 25' shouldn't be a problem at all. I wouldn't try to lift more than about 6 feet though. Don't know how effecient the pump is.
OBJ
If I streched it out that far, I think for sure I'd squeeze the primer ball before starting up cold and check the alarms often.
naplefish
who have jhonson 2000,175, millenniun edition ?
i dont know if i can mix the gas oil with the oil at the same time,is the first question and the second is ,,,i dont know where is the place to put the oil in the motor ?,please write me, to me email,,,,,,llurdita@hotmail.com,,,,,,,,,,,,,,,,,,,,,,,,,thank you
