2000 honda 8 hp it will pull start but it won't electric start
ridcbr
So I can pull start with no problems but the electric start is not working battery is fully charged as it start the big motor no problem I have also check the fuse and it is good as well where to go now thanks again
ridcbr
The battery is good and I cleaned all the connections and I jump the solenoid and it fired right up and I checked the actual start button and it has continuity so I'm not sure where to go now
vcaptain
don't just replace parts randomly, sounds like a bad connection. I went through the same thing, I replaced starter button, solenoid, etc, in the end it was the connection of the wire to the battery terminal. A mechanic once told me, always start with the most simple fixes, cause that's usually what it is.
