Chris Cole
Thread starter- Joined
- Apr 23, 2007
- 45
Hello forum,
Today I ran my mercury and again I had no greater than about 3500 RPM's. I took the cowling off while I was running the motor. It sounded like the motor was running on two cylinders, and sure enough when I put my hand over the throat of the top carburator there was no vacuum. The motor kept running just like it was while I held my hand over the top carb. I put my hand over the middle carb and the motor acted like it was gonna die. I put my hand over the bottom carb and the motor acted like it was gonna die. There was also a bit of racquet coming from the top cylinder when the motor was running. When I Idle I can get the top cylinder to start pulling some kind of vacuum, but not wide open. Can someone offer an opinion on what the problem might be???
Before you offer your opinions I have just changed the trigger( not the problem), disconnected the black/yellow from rev limiter while running
(not the problem), checked battery charge while WOT ( 13.9V), and checked spark. Compression on each cylinder is 120. Please help????
