guy48065
Thread starter- Joined
- Aug 31, 2008
- 575
Another spring, another problem preventing me from getting my boat in the lake.
Engine was running just fine when I put it up late fall, but won't start today.
Fuel flow from tank, thru bulb, and thru filter has been verified but the engine will only start on ether. Also there's no fuel spurting from the primer lines.
What is the path of fuel flow from the filter on? The factory service manual doesn't include a diagram of the fuel system.
I'm just baffled what's preventing pressurized fuel from getting to the primer lines (and carbs), either by electric priming or by manual bypass on the solenoid. Something seems to be blocking all flow beyond the filter.
