FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
my old powerhead had a hole in it so i bought a new reman block and my ? is do i need to do the timing on the new motor and any tips for the new motor??
First find out why that cylinder failed!!! Send the injectors and ECU off to have cleaned and checked or you may go thru this again. And yes you need to set the timing and check the spark advance box also. I would send you a link but Mercury has took down the 1manual site...
sorry still stuck on timing. manuel says i need timing light but where do i point the timing light too????? also i really dont get
"Turn flywheel counterclockwise until dial indicator needle is approximately 1/4 turn beyond0.462 in., then turn flywheel clockwise so that dial indicator reads 0.462 in.
(11.7mm) exactly" well i have the digital indicator will that work also????
