2000 115hp seems to starve for fuel
slburnham
My 115hp OceanPro starts and idles fine, but when the hammer is pushed down it coughs and spits and will not get up on plane. I also noticed some fuel leakage around top gasket of fuel pump assembly when I squeeze primer bulb pretty hard. The weird thing is that this was an intermittent problem and recently has gotten worse. Most boatyards aroung here are too busy to look at it any time soon.
Does any one know if there's a pump rebuild kit out there. I haven't found one yet.
Tanx,
Scott
ezeke
Re: 2000 115hp seems to starve for fuel
There are rebuild kits for the gasoline side of VRO/OMS pumps. The oil side is not rebuildable. OE part numbers are 435921 and 436095; you need both.
