summerlark1
- Aug 14, 2005
- 3
I am trying my hand at changing the water pump in my Merc 1995 200HP EFI Offshore. I purchased a Clymer manual and followed the lower gear case removal procedure (great manual btw).<br /><br />I removed all of the bolts, nuts, and miscell retaining devices. I double checked and I got everthing...but the darn thing will not come off. <br /><br />It does not seem to be terribly corroded, as the fasteners came off fairly easily. Clymer says on baddly corroded units, it may be necessary to hit it with a mallet or pry in off the upper housing!!!! I am reluctant to do that. I have used penetrating oil on all of the studs for a day or so, still no relief.<br /><br />I can actually move the lower gear housing a little and I can see light from the other side, so I do not think it is frozen. It almost seems like the gear splines are engaged and that is what is holding it up there, but the motor is in neutral and the prop shaft spins freely both ways.<br /><br />Do I really need to beat on this thing or pry it apart?????<br /><br />All help appreciated. I am relatively handy and this project looked to be straightforward...<br /><br />Dave
