200 2.4L powerhead swap
RGKSTV
Hello I am swapping a 1980 mariner 200 powerhead with a blown 1986 mercury powerhead, my question is: the 1980 Mariner that i am going to use had a flywheel with small teeth on it, I was going to use the starter from the 1986 mercury. but the flywheel on the mercury had larger teeth as well as the starter, can I just switch the flywheel from the merc and put it on the mariner or will that screw up the stator?
Thanks
Mariner SN: 5802197
Mercury SN: A943462
Faztbullet
Need to swap stator,starter and flywheel...Don't expect the same performance from the 80 model...
RGKSTV
Thanks! better to do it now then later.. nothing is ever easy hah
