2 problems n looking for some help
bronxrunner1
1st problem is does anyone know how far in and in which direction do the seals on the criculator pump go. I removed the old ones replaced them with new ones in the same direction in which i removed them but im still getting a leak out of the weep hole, 2nd problem is im having an overheating problem n i replaced the thermostat, the leakthat it has, im thinking cant be the cause of the overheating due to the fact that the motor is running for only 10 min b4 overheating begins, can anyone help the motor is a 1988 mercruiser 170 alpha 1. thanks
Haut Medoc
Re: 2 problems n looking for some help
Welcome to iboats.......:)
That site looks like it has alot of answers for the 470 beast....;)​
Bt Doctur
Engine side faces in toward the motor, A/F side faces foward.
But if your still weeping, what was the condition of the cam journal and were "speedi" sleeves installed.
