2 batteries 11.4 volts
skargo
Banned
I left something on obviously(the battery switch too) and both batteries were reading 3 volts or so. I charged both and my charger is saying they are full, but a volt meter reads 11.4 on them.
My question is are they both toast? We are going out tomorrow, and it looks like my first stop will be for batteries.
david_r
Re: 2 batteries 11.4 volts
are they sealed batts?
skargo
Banned
Yep, one was just purchases this spring.
steddy
First of all, are they deep cycle batteries? Deep cycle model batteries can be drained stone dead and left for quite some time, and as long as they don't freeze, normally can be charged right back up (slowly), and no damage will be done.
It's unlikely that this event took the lives of both batteries. For a fact, one of them might have been on its last legs anyway. Test them independently. Quick-and-easy low cost test: bring them to Autozone, fully charged. If you're savvy, however, you can remove the caps, and probe the cells with a multimeter with wire leads. With your multi meter set on DC, insert one of the leads in an end cell, and the other in the cell next to it. You should see 2 volts. Remove the 2nd lead, and put it in the next cell. 4 volts there, or thereabout. Put the lead in the 3rd cell (while the 1st lead remains in the 1st cell), 6 volts. And so on. If you get to the next cell and the meter's reading doesn't change by at least 2 volts, you've found your dead or dying cell. Replace that battery.
Repeat the process for the 2nd battery. Remember: when you hook them back up, make sure they go in parallel, not series. Otherwise, you will have a 24 volt system and start frying things.
steddy
Oops. Couldn't get posted in time. Serves me right for being long winded. Disregard the multimeter test for sealed batteries.
david_r
ouch!
what kind of charger are you using?
did you trickle the charge or sock it to it?
have you tried a different meter?......... not likely but maybe your readings are wrong.
on a sealed batt the only thing i can think of to try is put a load on it to pull it down some and try a trickle charge....... like 1.5-2amps
skargo
Banned
I charged them at 20 amps and one is still taking a charge. I will leave that one on for awhile at 2 amps, then hit the other with 2 amps as well.
One came with the boat, supposedly not old and it's a big mercedes battery. The 2nd I added, it's a walmart deep cycle. These batteries have never given me an issue. I start on the big merc battery, with my switch on 1, when we anchor I put my switch on #2, if it's for a long time I will recharge on both, but otherwise I keep it on #1 for recharging my start battery.
Blue Crabber
Ensign
How are the batteries doing this morning? I would have thought that your deep cycle should have come back at least after the slow charge overnight. Your starting battery is probably toast or at least its life is significantly been shortened! They just don't do well with deep discharges.
skargo
Banned
You hit the nail on the head Brandon! I'm going to run out and grab a starting battery that is more closely matched to my deep cycle.
david_r
im glad to see you only hvae to buy one batt.
i run all deepcycle/start batts in my boat.
my dad had 5 in his boat. 1 for starting and 4 for troller. i have only been able to get one of tem ot hold a charge............ they were practically bone dry when i took the caps off :eek:
i only run 3 batts. 1 for starter and 2 for troller, i feel safer knowing i can rob one of my trolling motor batts if i need to.
i like the priority start switch..... it looks pretty handy.
i never charge my batts with more than 6 amps at a time. they seem to last longer if you dont sock it to them......... if i know im not going fishin the next day i will only charge at 2amps.
