2.5l running question
85fourwinns
Ok so i got a 1985 with a 2.5l and its been sitting for a year or so and i put a new coil,points it started ran great at low rpm's and high rpm's shut it off for a sever hours and went to start it again and would only start at full throttle and if i held the choke valve open. Any help or suggestions is help full
dubs283
Re: 2.5l running question
did you change plugs, wires, cap, rotor, fuel filters, set dwell/timing??
these parts/procedures are part of a full tune-up
do you pump the throttle when trying to start the engine cold??
Ayuh,... Sounds like it might be floodin',.... Are the spark plugs gettin' Wet,..??
85fourwinns
Changed every but fuel filter and i didnt check the plugs after wards i just went inside and called it a night. And i pump the throttle two or three times to get some fuel in the intake
dubs283
sounds like its flooding, upon shutdown of the engine, check the carb throat to see if fuel is running/dripping out the venturi clusters
if so its time for a carb rebuild
