Bannister 6905
Thread starter- Joined
- Jun 5, 2015
- 110
The powerhead on my 1999 Evinrude E115FPLEEC is blown and I am in the process of removing it but have run into an issue. There are two 5/8" hex bolts that fasten the steering arm to the powerhead (?). These bolts seem to pass through a rubber mount(?) and then into the powerhead (?). I am unable to remove them using hand tools or using my impact wrench.
This is a fresh-water motor with no corrosion and everything on the powerhead is clean, except where the rod came through the block. These bolts are keeping me from removing the powerhead, so before I take my sawzall to them, I need to know if there's any specific trick to removing them.
Appreciate any advice will be appreciated!
