1999 Evinrude 50hp 4stroke cylinder head
yubby
First post here, thank you all in advance. Promise to give back as I complete this project, basically my first rebuild on a modern outboard.
Long story short ended up with a '99 50HP 4 stroke (twin to Suzuki DF50), had some water in the oil so made an impulse buy figuring it would be an fun project for my son and I. Once I got it on a stand found and did a compression test it came back 180/178/90. Even more telling than the compression test, water was actually being ejected out the #3 cylinder on compression.
Just got around to pulling the head off last night and saw a ton of salt and scale caked on the head (and some in the cooling jackets as well). Was able to remove most of it, but on the cylinder head it appears that the salt has eaten away part of the head. I was just removing the salt/scale with a small screwdriver and the aluminum was pretty brittle as well and was flaking off on the surface.
Is this something I can just take to a machine shop (have them grind, build up and reduce), or should I be looking at sourcing a replacement casting? The motor only has 150 hours on it, but was all in the salt and probably got its first flush a week ago..
Appreciate any thoughts here, see attached (head before and after scale removed).
Thank you!
yubby
Hi racerone,
I am located in Northern California. It looks like the head may be cross compatible with a DF40/DF50 up until 2010, so that may open up the possibilities for fix v. repair.
What is your take on the damage? Worth salvaging?
Typical example of 4 stroke complexity and corrosion damage.-------Couple of them listed on E-BAY right now.-----One where owner says he and his machine shop gave up on it.----Have 2 of them where motor hit rocks and damaged lower unit / vave train damage as well due to the "dynamic halt "----Just not worth fixing.
yubby
Good thing I have my trusty 2-stroke Tohatsu in reserve (probably over 1000 hours many in salt, but I have been the only captain!).
Guess I will take a stab at buying a "used" cylinder head and rolling the dice! At the end of it, may not make financial sense. But this one is looking to be more about the journey..
Put an offer in on the ebay DF40 head without cams. It looks to cross-reference (cams are the difference with DF50).
Thanks.
yubby
No Title
Here is the head I ended up purchasing (another $120 into it), but probably much cheaper than a machine shop/tig welding.
Looks to be in much better shape than mine (and 9 years younger). It came off a Suzuki DF40, so I can bring my cams over and be back in business. Not sure if I will need to reshim, but will do a spot check before putting it all back together..
cheers!
tommarvin
Ensign
Good for you, the head you bought looks great , you win paying $ 120 for the head .
yubby
All,
Just completed the rebuilt and got her running on the stand. Ended up just buying a new cylinder head casting instead of fighting with finding a used one that would work. At the end of the day, I want a seaworthy engine that will not leave me stranded-why take the risk on something I could easily eliminate.
Will post a few pictures along the way. Also ignore the sounds in the background (my kids were playing wall ball in the garage)--that part was not from the motor.
Also remember to attach that IAC hose behind the intake manifold--without that your idle is about 2700 RPM :) The hose was easy to forget the first time!
cheers -y
yubby
No Title
Here is the progression of much of the rebuild. Not sure I am authoritative expert on rebuilding an outboard, but I did grow up doing the same thing on big diesel engines and small engines on the farm.
About the only tools I had to buy were an inch-lb 1/4" torque wrench (took loosing a bolt to realize my 3/8" wasn't all that calibrated at 10 ft lbs) and a valve spring compressor ($14.99 from fleabay)
Hope this can benefit someone else!
cheers -Lucas
sutor623
Looks awesome man, great job!! That motor looks beautiful for its age. If you dont mind me asking, how much $ did you have in it for the parts for rebuild?
yubby
Like anything it was a slippery slope, started out buying the outboard for $500, new controls for $249, another used head for $120+80 to clean it up, then bought a new head for $1k, and misc parts were another $200 (2 new intake + exhaust valves, assembly lube, head gasket, 1207b). So in all about $2200. If I wouldn't have purchased a bum used head would be right at $2k'ish. As with anything it is easy to arm chair it say "yada yada 4 strokes, dynamic halt, corrosion, reliability issues, etc..." Since I built and will use this outboard, the only one I have to blame if it ever has problems is me!
Also FYI: All the parts I bought were cheaper sourced through Suzuki channels (than the evinrude/OMC equivalents).
sutor623
Cool man, thanks for that. 4 strokes have their place, that's for sure. I'd say you did pretty good altogether. That purchase price at $500 for the outboard turned out to be a heck of a deal!!
