1999 Dozi Hulk Hogans boat
crodgers1
I recently purchased a 1999 Donzi z23 that belonged to Terry Bollea (Hulk Hogan) I am having a problem with engine cutting out and backfiring when I throttle down and when I ease it up to 2000 rpm. I have dumped the fuel, changed the water filter, New Dist, rotor, coil,plugs and wires. All were in need to replace condition. When it starts cutting out I can spray starter fluid gently into the throttle body and it takes off. I hooked up an auxillary tank and same thing. Therefore if its fuel, I am thinking pump and or pressure regulator. The back firing is the kicker, I would think that would be an ignition timing issue. Engine serial number is 0L356438. I read this forum alot and see some pretty knowledgeable responses therefore I am posting this thread. Any ideas?
Don S
Re: 1999 Dozi Hulk Hogans boat
It's MPI, have you had it hooked up to a diagnostic computer to see what's wrong yet? Done any fuel pressure checks? etc.?
crodgers1
Forgot to mention that the tach works sometimes other it is off the gauge as high as the needle can travel.
Watermann
Hey brutha just do a leg drop on the top of it from a ladder and it should tap right out. Sorry couldn't resist!
Is there a check engine light on the console lighted up?
Don S
Disconnect the gray wire from the tach and see what happens. An internally shorted tach can kill the spark.
crodgers1
I read somewhere the tach can be a problem, Thanks I will try it and let you know.
crodgers1
LOL, Im getting too old for leg drops, Im having problems with the ladder!!!! good one tho!
emilsr
Hope you get her running good. How 'bout sharing some pictures?
crodgers1
Don I dont have a diagnostic tool, not sure which one would work in order to buy one. I did hook a pressure gauge to the fuel rail and it measured 5 psi at idle, 3000 rpm i nuetral and under the load when it started burping again.
crodgers1
all my pics say too large when I try to upload them. any suggestions? I will have to set my camera to a lower res and take some more.
Don S
If you want to share pictures of your boat, please post them in the Boat topics forum not here. This forum is about engine and drive repairs.
carey965
Photobucket. It will resize them for you
Pics pics pics i want to see this beast being a hulkamania fan as a kid lol
ponchoman
Maybe his daughter was conceived on that boat?! lmao off the top rope kinda stuff. Pics!!!
crodgers1
Don S. Low fuel pressure staying constant. Do you think that is the pump or the pressure regulator. How would one test to find out? I thought about shutting off the return to the pressure regulator and seeing if it increases the pressure and putting it under a load.
Don S
Just to get you started, HERE is the service manual for your engine. Going to take some reading and understanding of the system.
The manual itself can be a challenge to navigate and find what you want. I will look at it in the morning and give you some pointers if needed.
crodgers1
Thanks, Don. I may just replace the whole cool fuel system, due to the fact its a booger to remove and install.
Fun Times
Yes, using Mercruiser part number 91-805918A1 "fuel shut off tool" would be the correct way to test to see if the fuel pump has the ability to build up fuel pressure well beyond your engines recommended 30 psi. As you know 5 psi is way to low.
Also while the engine is running and fuel test gauge is connected, disconnect the fuel pressure regulator vacuum hose and see if the pressure rises almost 5 psi. that should help give you an idea if the regulator is functioning or not.
Volphin
Correct me if I'm wrong, but 5 lbs is WAY too low for an MPI fuel system isn't it?
crodgers1
yep, should be 40-43 lbs. question is regulator or pump. probably pump. good idea on regulator test, thanks...
