1999 Bryant 214 prop question
inside0ut
I just bought a 99 Bryant 214 with the 5.7 EFI and an Alpha one drive (1.47). There is a 19P Mercury Vengeance SS prop on it right now. I have not run it to WOT cause I live in PA and there is still ice on the rivers!
The prop that is on there now is alittle dinged up and I'm looking to swap it out. My question is...to what? I ski and tube so Id like a good hole shot. I would have a normal load out of 25 gal. gas, 4 people, and 50lbs of a cooler normally on the boat (3 on the boat with a skier in the water.) There are so many props to choose from and pitches I'm alittle lost.
Any help is appreciated!!
steelespike
When the water gets softer do some wot lightly loaded test runs.Remind us of your boat, motor,prop size and gear ratio.
Get us your wot rpm and gps speed.We need a starting point that will tell us how your setup works.
