Hello everyone,
This is my first time posting on this site. I would really appreciate any assistance with my circumstances.
My 1999 50hp Johnson 2 Stroke has been really acting up. When I attempt to start the motor it will not turnover when I leave the throttle in neutral. However, if I simultaneously turn the key and then throw the throttle into gear, it will fire right up. When I do this, I have to keep it in gear for it to run. The second I put it back down into neutral, the motor shuts down.
I?ve been reading a lot of forums on this site and my circumstances seemed like my fuel pump gone bad. I thought the fuel pump wasn?t pumping enough fuel while it was in neutral causing the motor to shut down. So I bought a brand new fuel pump and installed it. I also installed new fuel lines and new bulb. I also bought a little 6 gallon fuel tank, with new ethonol free gas, and 50:1 oil/gas ratio. This did not fixed the problem because the same issue was happening.
Then, I thought it could be the carbs so I spent a good part of a day removing both carbs and I thoroughly cleaned them. Reinstalled the carbs and tried it again. When I tried to start it. Same problem. It would only turnover if I threw it into gear while I was turning the key. The motor started up but when I dropped it back down into neutral, it shut off immediately.
After I do this a few times, when I try to turn it on it seems like the battery is losing juice. I think these circumstances seem like low RPM aspect of the stator isnt working. I am also thinking that maybe the rectifier or the pulse pack isn?t working properly either due to how it seems like the motor only working off the power being provided by the battery.
I got my hands on a meter to check the voltage going back into the battery while the motor is running. I started her up, she?s obviously in gear, took off the battery connections and tested them on the meter. When I took off the connections, while she is in gear, she continued to run. However, the meter read 0.03 volts while hooked up the meter. Does this mean barely no voltage is going back into the battery, causing the battery to die? I also put in a brand new battery last week so I know the battery couldn?t have died already. I?ve had to recharge the battery once already to be able to start her up.
Another issue is that when she?s in gear, the overheat light comes on. I had this motor fully serviced 4 months ago, when a new water impeller pump was installed. Could the overheating issue cause the motor to shut down while in neutral but not while it?s in gear?
Another aspect of my situation is that after I run her, an excess amount of oil/gas mixture comes out of the lower unit below the propeller. Why is this?
One last thing. When she?s in gear, she runs better when she?s trimmed all the way up. When I trim her down while she?s in gear, she shuts off easier. How can whether she is tilted up versus being tilted down effect how she runs? I?m baffled.
Does anybody have any insight on this? Any guidance would be greatly appreciated. Thank you ahead of time for assisting me!
