1999 4.3 Volvo Penta Gi overheating issue
Jhm1992
I have a 1999 4.3 Volvo Penta engine which had a bad oil pressure sensor so 1 fuel injector would stop spraying around 2500 rpm. I changed out the oil pressure sensor and now the fuel injectors are working just fine but all of a sudden it is overheating. I don't even know where to start checking for the problem. I would greatly appreciate any advice to help me find the issue. Thanks in advance.
did you backflush the system to remove and broken pieces of impeller or to clean out the power steering cooler?
Jhm1992
When you say backflush do you mean run water through the hoses? Because I took most of them apart and cleaned them out.
