windknotnc
Thread starter- Joined
- Apr 11, 2004
- 45
Can someone post the Link and Synch procedure for a 1999 Yamaha 200hp SWII as well as the correct backing of carb idle screws. I just replaced the middle carb and did a thorough soaking and cleaning of the other 2 carbs. I backed the idle screws on each carb out 2 turns. The engine cranked right up but is idling at around 500-550 rpm with the flush cup. Once warmed up the idle dropped a little and it will cut off on its own.
