1999 200 efi will not idle loads up
buck9475
I have a mercury 99 200 efi it loads up at idle and low speeds. Will not idle and stalls totally runs fine wide open. Any suggastions?
buck9475
Re: 1999 200 efi will not idle loads up
Plugs changed i just built the powerhead and broke it in with double oil,been building for powerheads for 6 yrs not to good with the computer controlled motors,someone told me efi have problems with there ecms
make sure tpi is set right,does it smoke alot check oil injection link rod make sure its not on back wards.make sure the marks line up,did you double oil the motor since you rebuilt it
buck9475
Originally posted by flatsfisher57:<br /> make sure tpi is set right,does it smoke alot check oil injection link rod make sure its not on back wards.make sure the marks line up,did you double oil the motor since you rebuilt it
