RealSeabee
- Sep 15, 2009
- 2
1998 Tracker by Mercury - 40 HP
Symptoms - I can get the boat (16.5' Tracker) up on-step and running at a steady 4,000 RPM's. It seems smooth through acceleration but can only maintain RPM's for approx 45 seconds then it starts to drop-off. It seems to settle at about 3000-3100 RPM's but since it is between on & off of step, I do not leave it there very long. If I bring the boat back to Neutral/Idle for a minute then accelerate again it will get back on-step but it holds it for only 35 seconds or so.
Work completed by a certified Marine Mechanic over the last 30 days:
1. Complete tune-up w/ new plugs
2. Carb rebuild kit with ALL new hoses and inlet's
3. Replaced fuel lines and bulb
4. New Control Box and cables
The boat has a mounted 12 Gallon tank. There have been periods where the boat has not been run so I figured I would rule out a fuel issue. Today I got a new 6 gallon tank and changed the motor over with fresh fuel and oil. Same symptoms as already stated. All totaled, I have about 700 in repairs at this point.
Any advice, angles or ideas are appreciated.
Thank you,
R/
Dave
Thank you,
R/
Dave
